1998 GMC Jimmy Fuel Pump Failure
MISSTIX3
1998 GMC Jimmy with 130,000 miles
How do you know the fuel pump has gone out? What type of sound does it make?
May 4, 2006 at 10:28 AM
SYNCRAIT
  • 235 POSTS
well if your fuel pump is bad it wont make any noise.... usually when you turn your ignition on you will hear like a whirring noise if its working correctly it will be coming from in or near your fuel tank. To see if it is the fuel pump take a rubber mallet and strike your fuel tank in the middle firmly; not as to puncture it ; while someone else trys to turn the engine over if this is the case replace it as soon as possible you dont want to do this more than a few times. hope that helps
May 4, 2006 at 1:17 PM
Suggested Repair
A working fuel pump usually makes a brief whirring sound from in or near the tank when the ignition is turned on; a failed pump is typically silent. As a check, have someone crank the engine while you firmly tap the middle of the tank with a rubber mallet without puncturing it. If that restores operation, replace the pump promptly and do not repeat the tap more than a few times.
Conversation Summary
The owner of a 1998 GMC Jimmy with 130,000 miles asked how to tell if the fuel pump has failed and what sound it makes. The expert said a bad pump usually makes no noise, while a working pump whirrs near the tank at key-on. They suggested tapping the tank with a rubber mallet while cranking and replacing the pump soon if that gets it running.
