1991 Oldsmobile Cutlass Supreme CKP Fix
GMC
CRAZYMECHANIC
I have a 1991 Oldls Cutless Supreme Int. with a 3.1 engine, and auto trans. I am trying to find the location of the crankshaft position on the engine so that I can replace it and save myself $800.oo
Apr 13, 2006 at 9:54 AM
LOSONE
  • 1,616 POSTS
It is behind the harmonic balancer and is fitted into grooves in the balancer. Look carefully and you can see the connection. "sometimes" you can remove it without removing the balancer but it is easier to remove it. It comes off easy and you can get to it by removing part of the fender well on that side. Good luck
Apr 13, 2006 at 10:11 AM
Suggested Repair
The crankshaft position sensor is behind the harmonic balancer, fitted into grooves in the balancer. It can sometimes be removed without removing the balancer, but removal is easier. Access it by removing part of the fender well on that side.
Conversation Summary
The owner of a 1991 Oldsmobile Cutlass Supreme International with a 3.1 engine wants the crankshaft position sensor location to replace it and avoid an $800 repair. The expert says it is behind the harmonic balancer in grooves, is easier to reach by removing the balancer, and can be accessed by removing part of the fender well.
