Big Block Chevy Firing Order
GMC
BRADSHEWMAKE
firing order for big block chevy
May 6, 2006 at 2:13 PM
BURRBRIAN
  • 158 POSTS
Hey Brad, As far as I know the firing order for chevy v-8's, small or big block, are the same. Most intakes have them on them somewhere but just in case your's doesn't they go 1-8-4-3-6-5-7-2. Usually running in a clockwise direction. Easy to check with dist. cap off. Let us know if you need any more info.
Happy to help :twisted:
May 7, 2006 at 1:57 AM
Suggested Repair
Use firing order 1-8-4-3-6-5-7-2 for a Chevy V-8, small or big block, usually running clockwise. Confirm the sequence on the intake if marked, or with the distributor cap removed.
Conversation Summary
The owner asked for the firing order of a big block Chevy. The expert said Chevy V-8 firing orders are the same for small and big blocks: 1-8-4-3-6-5-7-2, usually clockwise, and suggested checking the intake marking or the distributor with the cap off.
