1997 Grand Am Overheating and Coolant Loss
Suggested Repair
Pressure-test the cooling system and inspect for external leaks. Check the oil for coolant and, if no external leak is found, check whether coolant is entering the cylinders. Bleed any air from the system, since an air lock was suspected, and confirm the coolant is compatible rather than mixing incompatible types.
Conversation Summary
The owner of a 1997 Grand Am added Prestone long-life premixed coolant after a heater problem, then had the thermostat replaced. The temperature gauge now runs very high, the warning light comes on, heat is weak, and coolant is being lost. The owner asked whether using non-Dex-Cool coolant caused damage. Experts said coolant type is less critical out of warranty but incompatible coolant can cause problems, and unexplained coolant loss may indicate a serious internal issue. They recommended a cooling-system pressure test, checking for coolant in the oil, and checking for coolant entering the cylinders. The owner later said the car was being inspected for a possible air lock and that the spark plugs needed replacement.
