'64 Chevy Dead
1964 GMC
MIECZ
My '64 Chevy was running excellent. I pulled into a gas station. It would not restart. There were no head lights, nothing. Completely dead (everything). I had it towed home and and tried restarting, and, of course, after paying the tow truck guy, it started right up. The next evening, I took it out for a short run. I pulled into a parking lot driveway when suddenly, engine and lights quit at the same time. I was able to coast into a parking spot.
Items I have checked:
Battery- reads 12v, terminals looked good but I cleaned them anyway.
Battey cables- checked for continuity and OK.
Tested voltage of battery cable at starter. This was OK.
Tested ground cable to block- this seemed to be OK.
I do have an alarm system, but when activated the ignition switch is killed, but all lights still come on.
Any clues would be helpfull. Thanks!
Jan 16, 2006 at 2:06 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Arrange safe transport and have the main power and ground connections tested while the failure is present. Include the alarm installation in the electrical assessment without removing or bypassing it on speculation.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
RICHR
Easiest check is the ground cable, take it off and sand all areas making sure it has good contact.. Secondly I would rip that alarm system out if it is a 3rd party system. So many issues can stem from that.
Jan 16, 2006 at 5:17 AM
Discussion summary
'64 Chevy Dead
A 1964 Chevrolet intermittently lost all electrical power, including the engine and headlights. The owner reported checking battery voltage, cable continuity and connections; the vehicle also had an alarm system.
Reported outcome: No confirmed cause or completed repair was reported.
The reply suggested attention to the ground connection and blamed the aftermarket alarm without test results. The discussion does not establish which connection or component failed.
Read the original discussion
