2004 Other GMC Models XUV Envoy
2004 GMC
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOANNE706-2007
Hi, this afternoon the tail gate window was partcialy down and when I pushed the button to go back up nothing happened. so I pushed it up and it went down all the way, now it won't go back up, the tailgate will not open at all, I hit the large button on the side wall now the motor is running and it will not stop. I cannot find the fuse box, I can hear something in the tail gate running, . I locked the doors and had to call on-star to open them. The rear sliding roof will not respond either. I looed in the manuall to se what I should do and feel as if I followed directions for reset..
I came on the computer to see if I can find the location of the fuse box and found you...
Can you tell me where it's at ? I hope it's not the large box under the hood, it's pouring here. thankyou, joanne[img:ed601579f1]http://www.2carpros.com/forum/automotive_pictures/528145_100_4695_1.jpg[/img:ed601579f1]
May 16, 2010 at 10:22 AM
HMAC300
  • 48,601 POSTS
you've probably found it by now, but he fuse box is under the hood. everything should be pointed out there on the under side of the top.
May 26, 2010 at 8:50 AM
JOANNE706-2007
there are 2 fuse box's one under the hood and the second is under the rear seat, the seat has to be folded up..
May 27, 2010 at 7:06 PM
