1997 Other GMC Models surging,dieing
1997 GMC
21,577 MILES • V8 • 4WD • AUTOMATIC
SMITTY36LANCE
I just put a rebuilt 355 GMC in my suburban. It boggs,then surges with power all at once. Then it dies,restarting good,then after a matter of minutes,dies again. Can you help me? New fuel pump,distributor,pick-up coil inside distributor,rotor,i've replaced everything. FRUSTRATED!
Jul 20, 2009 at 2:58 AM
HMAC300
  • 48,601 POSTS
try cleaning the throttle body plate. this is the cause of alot of problems on cases like yours . Spray some choke cleaner on itndwipe with a rag on both sides. Ifit is a TBI unit then start the vehicle up and clean it while idling, it will tend to stall out so make sure to do it slowly. then if it also is a TBI, check te vacuum hose to teh map sensor and see if it is soft or collapsed. If it is replace it...
Jan 11, 2010 at 9:42 AM
