When going from 2 wheel drive to 4 wheel drive any mode AWD, 4 High, 4 Low push swith on dash lights flash the returns to 2 wheel drive. Never transfers from 2 whee drve to 4 wheel drive.
Any thoughts?
At key-on, confirm the 4x4 switch lights cycle (all yellow and one red). With a door open, shift in and out of 4x4 and listen under the vehicle: a whine without a clunk points to a bad encoder motor; no sound may indicate the TCCM. On a similar Jimmy where 4LO works but 4HI does not, start by replacing the inexpensive selector switch, which commonly fails.
A 1999 GMC Jimmy owner reported that selecting AWD, 4 High, or 4 Low makes the dash lights flash and then return to 2WD, so four-wheel drive never engages. The expert advised checking the switch light cycle at key-on and listening for the encoder motor; a whine without engagement suggests a bad encoder motor, while silence may indicate the TCCM. A second 1999 Jimmy owner said 4HI does nothing while 4LO works and mentioned a possible failed solenoid. The expert recommended trying a new selector switch first because they fail often.
