99 jimmy is it worth fixing?
NKELL
I've owned this vehicle for around 5 years. it now has 150,000 miles. I just got done changing the oil and i noticed trans fluid all underneath. Not only that, but it has been leaking oil from the intake gasket (about a quart between oil change). Both front wheel bearings are shot, the expensive abs ones. there are countless minor repairs that i need to do and there is costly body damage to the right front(just physical). my question is should i keep this thing or buy a new car? I can't really afford either but what would be cheaper in the long run?
Sep 16, 2007 at 9:33 AM
SERVICE WRITER
  • 9,123 POSTS
Figure out what it will cost to get it to "acceptable running....can you buy another vehicle that is the same cost...that you know what it needs?
https://www.2carpros.com/car_articles/buy_repair.htm
Sep 16, 2007 at 1:24 PM
