2001 GMC Jimmy Temperature Gauge
2001 GMC JIMMY
74,150 MILES • 6 CYL • 2WD • AUTOMATIC
MACK312
When I was driving my car the last couple of days I've noticed that my engine temperature gauge was not in the middle. It was about 3 - 4 lines over to the left. I haven't checked the coolant levels but I haven't had any spots where I've parked so I'm not sure if the gauge is bad or maybe my coolant evaporated. Can coolant even evaporate? I'd appreciate any help you can give me with this matter.
Dec 8, 2008 at 1:23 AM
  • 110,244 POSTS
Hi:
Coolant is designed not to evaporate; however, if you get it hot enough, it will. You said the gauge is to the left. Does that mean the engine is running cold? Also, if coolant is missing, check the engine oil to make sure it's not getting into the engine via a bad head or intake gasket.
Dec 9, 2008 at 2:34 AM
