2001 GMC Jimmy Fuel Pump has broken port
JHUB65
Engine Mechanical problem
2001 GMC Jimmy 6 cyl Four Wheel Drive Automatic
I am in the process of replacing my fuel pump and I broke the plastic return port at the top of the fuel pump. The port has broken with many jagged edges that fit together tightly without glue. Is there a glue that would work to adhere to this type of plastic and not be broken down by fuel?
I had also contemplated clamping a fuel hose to the whats left of the port. Any ideas or suggestions would be helpful. Thanks.
Jan 31, 2010 at 8:36 AM
BLACKOP555
  • 10,386 POSTS
if its return hose you could be able to put ahose clamp on it and put some sealer in it so you dont get a emissioin code to pop up. but first i would try geting some
Seal-all. found at auto part store is gastank repair solvent
works good and gets as hard as glass when done. id go with that.
Jan 31, 2010 at 1:42 PM
