1994 GMC Jimmy
JAYANDREW89
  • 1994 GMC JIMMY
1994 GMC Jimmy 6 cyl Four Wheel Drive Automatic
i was pulling out of my drive way and all of a sudden the engine just shut off, I checked the fuses they were all good I replaced the fuel pump, coil, distributor cap and rotter tested the ignition control module and it still wont start,
Thank you
Jason.
Tuesday, April 6th, 2010 AT 3:55 AM
INTERNETMECHANIC
  • 700 POSTS
Have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. Any applicable trouble codes?
Tuesday, April 6th, 2010 AT 10:54 AM
JAYANDREW89
My fuel pressure is kinda low not at sixty psi or where its supossed to be. The engine rotates but wont start my spark was bright orange then I replaced my coil an still dont start. There is no applicable trouble codes, please help thank you.
Tuesday, April 6th, 2010 AT 4:02 PM
INTERNETMECHANIC
  • 700 POSTS
What was the actual fuel pressure spec? If you have the spider fuel system, the fuel poppets may need cleaning. Do you have an injector pulse.
Wednesday, April 7th, 2010 AT 9:47 AM
JAYANDREW89
If I spray Carb cleaner in the intake it starts replaced fuel filter. I don't have pressure gage so I don't know how much but there is pressure checked single injector still good don't know please help thank you
Thursday, April 8th, 2010 AT 8:58 PM
INTERNETMECHANIC
  • 700 POSTS
Friday, April 9th, 2010 AT 9:29 AM
