2001 GMC Jimmy fuel gauge
2001 GMC JIMMY
146,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARCO672
fuel gauge always reading empty "Low Fuel Warning" even if the tank is full. The auto computer which displays how many miles you have left before refilling also reads "Low"
May 27, 2010 at 11:20 PM
  • 31,937 POSTS
Hi there,
I would be checking the tank sender unit, if you earth out the tank gauge wire with ignition on, the gauge should go to full, if this is so, the sender in the tank is faulty.
mark (mhpautos)
May 27, 2010 at 11:24 PM
