Will not start no matter what
TONY_LESLIE
  • 2000 GMC JIMMY
I have a 2000 GMC JIMMY about 3 months ago as I was driving to work in the morning I stopped on a red light when the light turned green I notice that my truck had turned off. I tried to turn it on but it only made the noise when its gonna start but it didn't. I ended up getting it towed to my house. I have checked for it to have spark and it has good spark I also checked for the fuel pump pressure and it has 55-60 psi. I also checked for it to have any codes but nothing came up. I put a new battery, and a new starter. Even if I prime it it wont start so is been 3 months and I haven't been able to get my truck started not even one time.
Friday, September 5th, 2008 AT 3:44 PM
MERLIN2021
  • 17,250 POSTS
Have you done a relearn on the pass-key?
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Friday, September 5th, 2008 AT 4:15 PM
ESTJAN14
My 2000 jimmy did that last week it wouldn't start and I had it towed to the shop and they had to replace the fuel pump.
Thursday, October 2nd, 2008 AT 11:47 PM
MERLIN2021
  • 17,250 POSTS
That good, but his pressure is pretty good.
Friday, October 3rd, 2008 AT 2:27 PM
