2000 GMC Jimmy hello
145,565 MILES • 6 CYL • 2WD • AUTOMATIC
85ANNA
i wasn't sure what category to pick. I have a 2000 GMC Jimmy, my gas gauge is not reading proprely, i can put 15gals and it will read full and then it will read low fuel when i stop and dive sometimes. Any suggestions.
Mar 17, 2009 at 11:46 AM
BLACKOP555
  • 10,386 POSTS
check the fuel pump connector for proper fit and for corrosion, you could also have a bad guage or sending unit in the tank.
to check disconnect sensor and turn key on, then ground it out and turn key on.
what do u find with the guage?
Mar 17, 2009 at 1:45 PM
