2000 GMC Jimmy automatic 4wd
188,000 MILES • 6 CYL • 4WD • AUTOMATIC
FRIENDLY100
the automatic 4wd keeps blowing the fuse, this started happening last winter out of the blue so I took it to the dealer they found that the fuse had blown so they replaced it and $75.00 later I was back in business, well at least for about 5 miles down the road when it blew again. My luck with this dealer is poor at best, so I will ask you if you have an answer to my problem.
Dec 6, 2009 at 2:48 AM
CRZYDRVR
  • 432 POSTS
There must be a short in the circuit. This would have to be traced down and eliminated. Also has it been checked for the right amperage of fuse?
Dec 7, 2009 at 2:55 PM
FRIENDLY100
problem solved. I read on another site that there was a sensor behind the passenger side kick panel that when the wiring was disconnected and the ignition switch turned on and off 5 times that it would reset the computer, so what the heck it was worth a try and sure enough it worked. Thanks for your input
Dec 7, 2009 at 10:54 PM
