1999 GMC Jimmy TRYING TO REMOVE LINKIGE
1999 GMC JIMMY
69JUMPSTART69
Transmission problem
1999 GMC Jimmy 6 cyl Four Wheel Drive Automatic
am trying to find the links to disconnect so the truck can be towed in nutrel.
Oct 9, 2010 at 5:34 AM
HMAC300
  • 48,601 POSTS
if you have the key turn the ignition on shift to nuetral and tow it. then be prepared to put a new trans in the truck asit will burn it right up. take the driveshaft out........
Oct 23, 2010 at 2:12 AM
