1998 GMC Jimmy Ignition switch or wheel shaft?
CLILLY
  • 1998 GMC JIMMY
  • 6 CYL
  • 4WD
  • 160,000 MILES
My car has gone through a lot of repairs and tuneups recently, including having several fuses replaced - but something new has started happening. Sometimes when I start the car the gages won't light up, and it won't show the mileage, fuel in the gas tank, etc. -- But it will light up the "Service Engine Soon" warning. When this happens, the ignition switch also sometimes locks into place so that I can't remove or turn the key, until I jostle the wheel a bit. The car will still start fine, and will also drive - although I've noticed it's very, very sluggish to accelerate when this happens. Typically the gages go back to normal after a few minutes of driving. And I have also found that if I deliver a swift bump to the steering wheel, the gages work properly again. This happens once every couple weeks, sometimes more.
I know pretty much nothing about cars - but IF it is just a faulty ignition switch, are those easy to replace? (I'm really broke, and would like to do it myself.) Or does it sound like it might be something different?
**Today the gages have been going in and out whenever I hit a bump on the road. Other than the engine feeling sluggish, maybe this is something I don't need to repair (. She asks hopefully.)
Sunday, April 19th, 2009 AT 4:44 PM
2CARPRO JACK
  • 11,533 POSTS
That is most likely going to be the ignition switch. Have seen similar problems before. You can do it yourself. Remove knee bolster.
- Remove upper and lower halves of steering column shroud. You don't need to remove steering wheel, multifunction switch or lock cylinder, or drop steering column.
- Unplug small black connector near lock cylinder, and using directions in Fig.2, remove white key alarm switch from lock cylinder.
- Using two screwdrivers, depress locking tab on either side of ignition switch and pull switch out of lock cylinder.
- Cut a million zip ties to seperate ignition switch harness from other harnesses and unplug large connector at base of steering column. Switch is out! Reverse for reassembly.
Wednesday, April 22nd, 2009 AT 7:59 AM
