1995 GMC Jimmy ignition key
GROG
  • 1995 GMC JIMMY
  • 6 CYL
  • 122,400 MILES
I put the key in the ignition and it won`t turn it`s like someone switched my keys
Tuesday, January 1st, 2008 AT 9:10 AM
BLACKOP555
  • 10,371 POSTS
First try another key, and secondly is your antitheft system functioning properly? Try some graphite lock lube sprayed in the cylinder and insert the key and remove several times and tap on the cylinder, if this dont work you may have to drill it out and replace.
Tuesday, January 1st, 2008 AT 12:11 PM
