HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
GMC
Jimmy
Electrical
Ignition Switch
Key
SPONSORED LINKS
1995 GMC Jimmy Key sensor
TERRY0848
MEMBER
1995 GMC JIMMY
6 CYL
2WD
AUTOMATIC
161,000 MILES
Key sensor stay on when key is in the ignition even when the auto is runing.
Tuesday, August 31st, 2010 AT 9:01 AM
WRENCHTECH
MECHANIC
There is no "on" or "off" to the key sensor. What is the car doing?
SPONSORED LINKS
Tuesday, August 31st, 2010 AT 9:11 AM
TERRY0848
MEMBER
The same sound that it makes when you put the key in. It is still making it after the car is runing
Tuesday, August 31st, 2010 AT 9:28 AM
WRENCHTECH
MECHANIC
Oh, I see what your talking about. I thought you were referring to the security system.
The key buzzer only goes off when the door is opened but it shouldn't happen with the engine running.
Are you sure it's not the seat belt buzzer?
Tuesday, August 31st, 2010 AT 11:51 AM
Please
login
or
register
to post a reply.
Related Ignition Switch Key Content
1995 Gmc Jimmy Ignition Key
I Put The Key In The Ignition And It Won`t Turn It`s Like Someone Switched My Keys
Asked by
grog
1 ANSWER
1995
GMC JIMMY
I Was Installing A New Ignition Lock Cylinder On My...
I Was Installing A New Ignition Lock Cylinder On My Friends 95 Jimmy, Using The Instructions From A Haynes Repair Manual, And I Got The...
Asked by
Bsk21088
1995
GMC JIMMY
Ignition/key
My Key Will Not Turn In My Ignition. The Steering Wheel Is Not Locked And My Vehicle Is In Park. I Am Able To Remote Start It But Starting...
Asked by
Aisforalexis
1 ANSWER
2005
GMC JIMMY
2001 Gmc Jimmy Key Will Not Come Out
Other Category Problem 2001 Gmc Jimmy Engine Size Unknown Four Wheel Drive Automatic 130000 Miles When I Turn The Key To Get It Out...
Asked by
steph12
2001
GMC JIMMY
1999 Gmc Jimmy Key Wont Turn Off
I Cant Get My Key Out Off Ignition All The Time
Asked by
rltalfo
1 ANSWER
1999
GMC JIMMY
VIEW MORE
SPONSORED LINKS
Battery Replacement Ford
Battery Replacement Video
Battery Replacement Toyota
Online car repair manuals
