1997 GMC Jimmy Faulty Fuel Pump?
ASHLEYD
  • 1997 GMC JIMMY
  • 6 CYL
  • 4WD
  • 120,000 MILES
I have a '97 GMC Jimmy that I've been having problems with since last year. I replaced the fuel pump with a pump from the salvage yard last summer, replaced the filter, new coil, new ignition rotor, new battery, new distributor head. Just the other day, I cleaned out the carbon deposits from the EGR valve & bolted it back onto the engine. The truck will run and suddenly die. Sometimes it will start right back up, other times it won't. I can hear the fuel pump when I turn it on -- I'll start it up and it will idle just fine. But if I turn it off, and then turn the battery on again. I won't hear the fuel pump, the engine will start and instantly die (it probably uses the rest of the fuel in the line & runs out)
I've tried to replace so many things, when it does run occasionally it will seem like it's not getting gas and will sputter and the RPMS will jolt, and it will die. Other times, it will simply die. When it turns over and won't start, I know it's getting spark so it has to be fuel?
HELP!
Thursday, June 26th, 2008 AT 10:21 PM
Good observation-
Lets start checking the fuel pump relay-if its check out-confirm the actual fuel pressure to rule out the pressure regulator/fuel pump. The computer energizes the relay for 2secs when the engine fires up the oil pressure sending unit powers the fuel pump see below
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_60.gif
Thursday, June 26th, 2008 AT 11:36 PM
ASHLEYD
Is this something I could fix myself without taking it to a mechanic?
Tuesday, July 1st, 2008 AT 4:18 PM
Yes if you know how to use a DVOM and read schematic diagram and a repair manual that has the electrical wiring diagram
Wednesday, July 2nd, 2008 AT 2:48 PM
