1996 GMC Jimmy Will not turn on in cold weather
NANCYBOBE1116
  • 1996 GMC JIMMY
Electrical problem
1996 GMC Jimmy 6 cyl Four Wheel Drive Automatic 140.00 miles
My 96 GMC Jimmy will not turn on in cold weather. It starts with no problem at all but when it reaches 15 degrees or lower it will not turn on. The fuel pump was changed and a tune up was also done.
Monday, January 4th, 2010 AT 12:00 PM
  • 109,885 POSTS
Has the check engine light come on? Also, has the temp sensor been checked? It determines how rich or lean to make the fuel / air mixture based on temp. If it thinks it's warm out, it will cause this type of problem. Basically, it took the place of the choke on the old carbs.
Monday, January 4th, 2010 AT 12:58 PM
