The number one problem with your compressor, the GM HT6, mounted right on top of the engine, is case o-ring leak. The leak is usually located under the compressor, and is often missed because it's a hard place to get a light in. Once you remove the compressor though, you'll see it. Not a plug, but the link below has our write-up on the compressor, and the benefits of replacing it with a pinned unit.
The good news is that replacing that compressor is very easy, and fairly inexpensive.
SPONSORED LINKS
Wednesday, August 27th, 2008 AT 9:52 AM
