1996 GMC Jimmy speedometer
1996 GMC JIMMY
56,000 MILES • 6 CYL • 4WD • AUTOMATIC
CAMPWIZARD
the speedometer quits working once headlamps or parking lamps are on,but it is not effected by daytime running lites. So at nite i set cruise control and it works fine but the speedometer does not move . once you stop for 5 or 10 minutes it will then work fine for another 10 minutes then hand will remain stationary.
Mar 6, 2008 at 1:31 PM
2CARPRO JACK
  • 11,533 POSTS
But the cruise works when the speedo doesnt? The Speed sensor feeds info to the PCM (computer) it in turn gives a signal out to the speedo for how fast you are going. I would look for a loose/poor connection in the back of the instrument cluster. Sounds like it is losing something when the lights come on, which could be an indicator of a bad connection that cant handle any load on it
Mar 6, 2008 at 11:38 PM
