1996 GMC Jimmy
FLEZE2
  • 1996 GMC JIMMY
Engine Mechanical problem
1996 GMC Jimmy 6 cyl Two Wheel Drive 180000 miles
accarding to manuel the fuel line should have constiont presure. When I turn on the key. I have pressure at fuel filture. After I reconnect the fuel filture line.I check pressure at carburature and there was no pressure.I then cycle the key and there was pressure at the carburature but not enuff to start the car. The car will not start because of no fuel. When I pure fuel into the carburature the car start. Need help please.
Sunday, June 20th, 2010 AT 12:42 PM
INTERNETMECHANIC
  • 700 POSTS
You need to use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. If you have the spider fuel system, 60--66 psi fuel pressure.
Sunday, June 20th, 2010 AT 2:50 PM
