1996 GMC Jimmy
TOMARAS
  • 1996 GMC JIMMY
  • 6 CYL
  • 4WD
  • 189,500 MILES
The check engine light came on two days before my problem. When I put the key in the ignition I have power the cluster, when I turn the key to start the engine I lose all electical power. The cluster loses all power and the engine will not start. No power to the start as well.
Tuesday, September 29th, 2009 AT 3:36 PM
  • 109,885 POSTS
First, start at the beginning. Check the battery terminals to make sure they are clean and tight. Also, check the ground to the engine block. To me, based on your description, it sounds like a bad connection.
Let me know what you find.
Monday, October 5th, 2009 AT 8:58 AM
