The vehicle stopped running in the middle of the road and there's no spark.
Sunday, March 1st, 2009 AT 10:48 AM
JDL
MECHANIC
Take the coil wire loose from cap, hold close to engine ground, have helper crank it, does a spark jump?
If not check the primary circuits to the coil, pink is B+, goes hot when you turn on the key. White is ground/tach signal, should be a pulse with the engine cranking.
