1995 GMC Jimmy not starting
JMC2009
  • 1995 GMC JIMMY
  • 6 CYL
  • 4WD
  • 180,000 MILES
I got out of my truck and when I got back in not even fifteen minutes later it wouldn't start. It sounds like it wants to start but just won't. Please help. It has gas, It's not the starter or the battery.
Saturday, November 8th, 2008 AT 6:17 PM
Do below to determine if its fuel or spark problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, November 8th, 2008 AT 6:23 PM
