1995 GMC Jimmy engine won't start when hot
JASON9591
  • 1995 GMC JIMMY
  • 6 CYL
  • 4WD
  • 191,000 MILES
My truck starts fine in morning or after it sit at least 4 hours but when it hot it just keeps turning over and won't start. When its hot it will start perfect if you shut it off and start it right back up but if you wait about 5-10 mins it wont start but somestimes it does start and runs but it misses and won't idel for about 30 sec then it runs perfect. Fuel pressure checked good no engine light on, replaced air charge sensor, tps sensor, iac valve, tried a used map sensor, plugs, wires, cap, rotor, control module. Coil was replaced 2 times first one worked for about a week may this is still the problem. I think its heat related
Wednesday, May 21st, 2008 AT 5:54 PM
MMPRINCE4000
  • 8,548 POSTS
I would look for an exhaust leak in the exhaust system or header, or a heat shield that is missing. Also check that the EGR valve function, (connections, heat tape, broken bolts). Check TPS sensor also.
Check the convoluted tubing (the split plastic tubing covering most wiring) for burns. You can buy a silicon tape that can be used to replace/fix it, but if there is an exhaust leak it will defeat most tapes except firesleeve.
If the coil is the problem, it may be exposed to an unwanted heat source as explained above.
Wednesday, May 21st, 2008 AT 8:01 PM
