1995 GMC Jimmy brake lights
1995 GMC JIMMY
212,000 MILES • 6 CYL • 4WD • AUTOMATIC
WAFER64
  • 11 POSTS
brake lights don't work checked fuses, bulbs all good but third brake light on hatch works could it be the brake light switch on the pedal
Apr 17, 2010 at 2:26 AM
INTERNETMECHANIC
  • 700 POSTS
No, not the brake-switch. The lower brake lites are wired through the multifunction switch, the high-mount brake lite isn't, they both get voltage from the same brake switch, the routing is different. The lower brake lites and turn signals use the same bulb filament, just not at the same time. The problem is probably the multifunction switch or wiring in the steering column. Any fuses that you checked, did you use a voltage tester to see if circuit is hot? Do the turn signals work ok? I can give some wiring colors if you want to do more testing?
Apr 17, 2010 at 2:44 AM
WAFER64
  • 11 POSTS
turn signals work but also the emergency flashers do not checked flasher relay beside ciarette lighter it is good
Apr 17, 2010 at 3:01 AM
