1994 GMC Jimmy 94 Jimmy fuel pump / no start
CHRISTOPH80254
  • 1994 GMC JIMMY
  • 6 CYL
  • 126,000 MILES
I have a GMC jimmy 1994 with 126000 miles. It left me stranded the other day. I replaced the fuel pump and filter and sending unit today. It still will not start. If I put gas in the intake it runs fine till it burns it off. I checked the bleed off valve right behing the manifold and its getting gas all the way to the intakes. Im at a loss on what to do to get my truck running any advice would be greatful! Thanks for your time.
chris in louisiana
Saturday, March 29th, 2008 AT 9:25 PM
MERLIN2021
  • 17,250 POSTS
I think Raz is refering to the oil pressure/fuel relay cutoff switch on the top rear of the engine, also does the pump run for 2-3 seconds after the key is turned to on? Have you checked for power at the pump?
Sunday, March 30th, 2008 AT 5:55 AM
CHRISTOPH80254
Yes when I turn the key the pump kicks on for 2 seconds. I can hear it. So I should check the oil pressure fuel relay cutoff? Is that the same thing as the fuel pump relay?
Sunday, March 30th, 2008 AT 8:06 AM
MERLIN2021
  • 17,250 POSTS
No. The oil pressure switch is on the top rear of the engine, If this is the CFI unit check for brittle wires at the injector.
Sunday, March 30th, 2008 AT 8:14 AM
MERLIN2021
  • 17,250 POSTS
Check the CFI unit's wires.
Monday, March 31st, 2008 AT 12:54 PM
