1992 GMC Jimmy Intermittant PA/C Problem
NANCY BOSCO
  • 1992 GMC JIMMY
Air Conditioning problem
1992 GMC Jimmy 6 cyl Four Wheel Drive Automatic 169k miles
My 1992 Jimmy's a/c will work fine at the beginning
of the day or if the heat is a dry heat. However, once the air is hot and humid, the unit only blows warm air.
Monday, June 21st, 2010 AT 12:25 PM
HMAC300
  • 48,601 POSTS
Have apro check this, it sounds like you are getting what is normally called freeze up. If that's the case it will need to be evacuated an d recharged as well as haveing the drier replaced.
Sunday, June 27th, 2010 AT 8:36 PM
