I didn't drop the tank to replace my fuel pump. This guy talked me into using a pump you mount along with fuel lines. Now I don't know what the hell is wrong. I should have dropped the tank. I have every thing hooked up right is the pump or something from my tank causing a problem also I replaced my fuel lines because they were cut and so theres another problem. I tried to start the jimmy but it just cranks no start
SPONSORED LINKS
Tuesday, January 1st, 2008 AT 1:43 PM
