2005 GMC Envoy surging
2005 GMC ENVOY
78,000 MILES • 6 CYL • 4WD • AUTOMATIC
DOMSTECK
My vehicle surges while normal driving operations. So if I am going around 60mph I get to feel this annoying up and down acceleration, seems to be worse when my tank is about a 1/4 full. I have had it in the shop twice and had the computer flased as well as the throttle body changed out. Not sure where to go from here.
Mar 26, 2010 at 6:31 AM
DOCFIXIT
  • 18,828 POSTS
The first thing you want to do is check the fuel pressure here is a guide to help you see if you have a weak fuel pump which is normal on these cars. Good fuel pressure 55-62 psi.
and if bad here is what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Check out the diagrams (Below)
Please let us know what you find.
Cheers
Mar 26, 2010 at 7:38 AM
DOMSTECK
Thank you it was the fuel pump I got one on Amazon for $210.00 Ac Delco
Mar 28, 2010 at 7:08 AM
