2005 GMC Envoy Power Windows
41,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKECALZONE
Power window buttons do not work from the driver door console. The windows do work if you use the power window button from the respective door.
Please help.
Nov 11, 2008 at 5:40 AM
  • 110,248 POSTS
Hi:
To me it sounds like the switch may be bad in the driver's door. You will need to remove the panel to get to the switch. Once you do that, make sure all connections to the switch are clean and tight ane are getting power. If they are, have the switch checked.
Let me know if you have any other questions.
Dec 2, 2008 at 9:52 AM
