2004 GMC Envoy Check engine light won't go off and stay off
LSOLIVETO
MEMBER
2004 GMC ENVOY
6 CYL
2WD
AUTOMATIC
12,600 MILES
How to reprogram the the computor after there was extensive work done in replacing numerous sensors.
Is there a way to fix the computor or must I replace the whole unit.
Saturday, July 10th, 2010 AT 1:13 AM
HMAC300
MECHANIC
First make sure the battery cables are clean and the battery is in good shape. If it's not it will cause problems. Then get a scanner and see if you can clear the codes. Each time a sensor is replaced the code has to be cleared with a scanner.
