2004 GMC Envoy check engine light on
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
DH0167
had a diagnostic done and it says a thermostat problem or sensor. engine does not overheat. so, could thermostat be bad anyway?
Aug 29, 2009 at 10:31 AM
  • 75,988 POSTS
Test the thermostat and coolant temperature sensor
Aug 29, 2009 at 10:37 AM
MIKESMECHANICAL
  • 6 POSTS
It should be pretty easy to check if the thermostat is bad, you say it doesn't overheat, is your vehicle equipped with a guage? If so does the the temperature rise into the normal range when driving, if not the thermostat may be stuck open, if it does rise to normal you may have a problem with your coolant temperature sensor. Both of these repairs are relatively inexpensive to have done, if you are trying to save the diagnostic fee you could probably replace both with parts from a do it yourself parts house. Remember coolant is hot and may be under pressure so please let your vehicle cool completely prior to opening the cooling system or removing the radiator cap. You may have to have the trouble codes cleared from memory after completing repairs.
Aug 29, 2009 at 11:04 AM
