No Crank Reduced Power?
158,000 MILES • 2.9L • 4 CYL • 2WD • AUTOMATIC
NOLA JAX
  • 13 POSTS
While driving 60 MPH, my engine stalled, the dashboard displayed Reduced Engine Power, then shutdown. Pulled to side of the road and would not re-start. Had to tow back.
The only OBD code was P0365, however, after extensive testing and replacement, I have figured the DTC showed-up because the camshaft is not moving. The exhaust camshaft sensor (CMP) is good/replaced and does not see the reluctor wheel spinning. Therefore, the P0365.
Outside of that, the only other OBD codes are related to my On Star system, which I do not use.
Unfortunately, I replaced the starter through great hassle. Poor GM design. Turns out I replaced a good starter with a new one.
In the process, I accidentally crushed the injector fuel harness, which had its looming completely deteriorated. Poor GM design. Had to take the intake manifold back off and rebuild the harness.
Re-installed the harness, re-installed the intake manifold, re-installed the throttle body and resonator. Everything back installed, no fuses blown and still the starter just spins.
What threw me off was the crankshaft sensor (CKP) was actually reading some RPM (around 160) while attempting to start. The flywheel was not turning, as it was guessed the false reading was coming from interference from the starter motor. All these are in close proximity.
The crankshaft will not turnover.
Oh, and through a fiber optic camera, discovered the timing chain was not thrown/broken.
Decided to change oil and filter while the truck was on floor jacks. No metal fragments in the old oil.
Where I am at now is the ignition switch is turned to start, the starter spins (I do not think the pinion gear is engaging the flywheel), and yet the truck does not start.
The battery is a few months old and has checked OK.
Something just tells me this is a ground issue, wiring issue, or somehow the ECM is stuck on Reduced Power Mode.
Have pulled both battery cables and shorted the two with jumper cables to load/drain any residual power in the system.
All lights and systems seem to work just fine. Just no cranking, though the starter spins.
The odd part of what I see in the dashboard display is a check engine light (CEL) and the mileage displayed. The only time I have seen just the mileage displayed is whenever I have disconnected the battery. Usually, I insert the key, turn to on and the tripometer is displayed. Have to manually push the switch to change to mileage. As if the ECM is stuck in a mode.
By the way, last year went through some issues and thought the ECM was bad. Ordered a new one and had it pre-programmed. Did not solve my issue at the time, which was a crankshaft position sensor. So, I returned the one I bought for a refund and re-installed the factory original ECM.
As a side note, my TPMS system was displaying Low Tire, meaning low tire pressure, and that no longer displays after this shutdown failure. The tire are properly inflated. All TPMS sensors are new, yet the on-board system just will not read the sensors. I just dealt the with warning dings when starting as an annoyance and just live with the problem. Not sure if any of that would prevent the truck from starting.
Cannot find anything remotely similar to what I am experiencing.
Any thoughts, help and advice are welcome.
– Stan
Jan 22, 2024 at 3:38 AM
  • 55,694 POSTS
Hello Stan,
It sounds like the engine has had a internal mechanical failure, so you say you can hear the starter working but the engine does not turn over? Can I get a short video of what is happening, that would help a lot. You can upload it here with your response. We need to hear the noise, so we know which direction to go to help you fix the car. It takes time to upload so please be patient.
Let see if you can rotate the engine over by hand, this guide will help:
https://www.2carpros.com/articles/engine-seized-test
Code P0365 Camshaft Position Sensor B Circuit Bank 1.
Also, this guide may help as well:
Thanks for the details but I need a little more information so we can travel in the right direction to fix the truck. Please go over these guides and get back to us.
Jan 22, 2024 at 4:03 AM
NOLA JAX
  • 13 POSTS
Ken,
Will upload the starting demonstration video in the next hour. However, in the meantime...
Thanks for the prompt reply.
Everything listed in that "Code P0365 Camshaft Position Sensor B Circuit Bank 1" link has already been accomplished. All relays and fuses are working.
As for manually cranking the engine, I have not attempted.
Will explore that testing. Need to see if I have any tools to perform this test.
One thing I am interested in is whether or not there is a control wire on this model which signals the solenoid to engage the flywheel. I cannot find a schematic wiring diagram for this circuit.
The starter motor clearly is spinning (see the forthcoming video) however, it seems the solenoid is not kicking the pinion gear into the flywheel.
I would think I would hear a metal clunking sound if the gear kicked-in and the flywheel was seized.
– Stan
Jan 22, 2024 at 4:45 AM
NOLA JAX
  • 13 POSTS
Here is the start cycle from the dashboard...
What I find odd is right after I release the key from the start position, it seems as though the dashboard resets.
As opposed to just seeing the last screen display just before start.
Make sense?
– Stan
Jan 22, 2024 at 6:28 AM
NOLA JAX
  • 13 POSTS
Here is the start cycle from the engine...
Jan 22, 2024 at 6:29 AM
NOLA JAX
  • 13 POSTS
Confirmed the crankshaft does rotate freely and the AC compressor and alternator/generator pulleys work.
Jan 22, 2024 at 10:39 AM
  • 55,694 POSTS
Yep, this engine has come apart internally. Thanks for the video. With this many miles on it I would get a rebuilt engine from GM. Here is how to remove the engine so you can install a new one. Check out the images (below). Let us know how it goes.
Jan 23, 2024 at 2:24 AM
NOLA JAX
  • 13 POSTS
Thanks for the follow-up, Ken. Would you happen to have schematics for the TCS?
Jan 24, 2024 at 6:55 AM
  • 55,694 POSTS
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Jan 26, 2024 at 2:25 AM
