2006 GMC Canyon Left turn signal
84,000 MILES • 4 CYL • 4WD • MANUAL
ROY BURCH
I have no left signal front or back when using left signal device, I do have all hazard lights working and right turn signal. I just replaced the combo mutifuntion switch. The left turn signal worked fine until I turned on the right which worked fine and went back to the left which no longer worked. I disconnected the positive battery cable for 5 seconds and put it back on and they worked again for about 30sec. and was speratic at times put the right on again and left did n ot work again. unhooked cable from battery again and they started working again for about 20sec and would blink speratic again, then not work at all. unless i reboot the system again.
Nov 6, 2010 at 12:04 PM
KHLOW2008
  • 41,812 POSTS
Hi Roy Burch,
The turn signals are linked to the Body Control Module and you should start with retrieving for trouble codes with a scan tool.
If there are any B codes, let me know what they are and we can proceed with diagnostics.
Nov 6, 2010 at 7:53 PM
