2005 GMC Canyon trouble with module?? radio stays on after
2005 GMC CANYON
60,125 MILES • 4 CYL • 2WD • AUTOMATIC
BCIBOLTMAN
The radio remains on after the engine is turned off and the drivers side door is opened. If the windshield wipers are on, they also remain on. I can ope the passenger side door and they turn off. Drivers side window just repaired because it "fell". Put new actuatur in and now we have this problem. Have replaced "jamb" switches already with no luck.
Manual show BCM (body control module) in wiring diagrams. Is that the problem? Also the airbag light on the dash remains on and will not go out.......HELP!!!!
Mar 17, 2010 at 12:01 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Wow! You have some interesting problems. As far as the radio / wipers, I would recommend having the BCM checked. That could be the cause of the problems. As far as the air bag light, you need to have the computer scanned to identify what is causing that problem. It could be a sensor. NOTE: Most nationally recognized parts stores will scan it for free for you.
Have it checked and let me know what you find.
Mar 19, 2010 at 12:38 PM
REXBART
I am having the exact same problem! Please let me know how the truck was fixed. Thanks. Steve.
Nov 28, 2010 at 11:16 PM
