2005 GMC Canyon idle problem
GGALETTO381
Shakes or Wobbles problem
2005 GMC Canyon Four Wheel Drive Automatic 63000 miles
The truck vibrates when idling at a red light but does not vibrate when driving i think it may be something in the fuel injector maybe idk though hopefully you can help thanks... there is no check engine light on either
Feb 7, 2010 at 11:12 PM
MADMIKE1735
  • 951 POSTS
only at idle, i would look into the IAC (idle air control) its located on the throttlebody... possible a piece of carbon is causing the solenoid to stick.... clean it out with some carb clean, and see if that helps...
Sep 7, 2010 at 6:11 AM
