2004 GMC Canyon replacement fuel filter
RJANDERSON
Engine Mechanical problem
2004 GMC Canyon Four Wheel Drive Automatic
replacement fuel filter has plastic clips on in and out ends. When removing old fuel filter these plastic clips are not present. Line disconnects from old filter easily but no clips on old filter. Should I remove clips from new filter and put it on or are old clips stuck in the line? I have cross referenced at different retailers and manufacturers to be sure I have the correct part.
Mar 4, 2010 at 11:57 AM
HMAC300
  • 48,601 POSTS
yes the clips are either stuck in the filter or on the line..
Apr 2, 2010 at 1:16 PM
