1995 GMC C1500 Engine Squeal
KYLE.E
1995 GMC Z71/210k miles/5.7 L
I have a squealing sound coming from the engine compartment. It's more pronounced when the truck is in gear, although lightly pressing the accelerator with my hand (while in park) it squeals only briefly. It gets louder as I accelerate, speeding up to the point where it begins to sound like a tapping sound. I tried to locate the sound with the hood up pulling the throttle cable, but can't isolate it. Plus it's hard to duplicate the sound while in park. A/C on or off makes no difference. I've replaced the belt to a "gator back(?)" but it's still doing the same thing. Could this be as simple as replacing the belt tensioner or is it more complicated than that?
Nov 23, 2007 at 6:43 AM
MERLIN2021
  • 17,250 POSTS
The first thig I would do is remove the tension the check all pulleys by hand, anything that binders or wobbloes is a concern, pay particular attention to the tensioner, and the idler if you have one. With 210,000 miles I would change both on principle!
Nov 23, 2007 at 6:50 AM
Suggested Repair
Release belt tension and spin every accessory pulley by hand. Replace any pulley that binds or wobbles, especially the belt tensioner and idler. At about 210,000 miles, replace the tensioner and idler as a matter of course.
Conversation Summary
The owner of a 1995 GMC with a 5.7L engine and about 210,000 miles reports squealing from the engine compartment. It is louder in gear and with acceleration, sometimes becoming a tapping sound, and is hard to duplicate in park. A/C operation makes no difference, and a replacement belt did not stop it. The expert advises checking all pulleys by hand after releasing tension, focusing on the tensioner and idler, and replacing both given the mileage.
