1999 GMC C1500 Rear Disc Brakes
DBECKWITH
I am going to help a friend replace brake pads on his 1999 1500. It has 4 wheel disc brakes. The only time I have worked on rear discs was on a Mustang and I needed a speciall spanner to back off the adjustment on the rear calipers.
Is there anything special I need to have in order to work on Chevy rear discs?
Jan 30, 2006 at 8:49 AM
  • 55,616 POSTS
The emergency brake is integrated in the the rotor on the inside so there is no special tools required to reset the caliper. :wink:
Jan 30, 2006 at 9:56 AM
Suggested Repair
No special tools are required to reset the rear calipers on a 1999 Chevy 1500 with rear disc brakes, because the emergency brake is integrated inside the rotor.
Conversation Summary
The owner asked whether special tools are needed to back off the rear calipers when replacing brake pads on a 1999 Chevy 1500 with four-wheel disc brakes, noting that a Mustang required a special spanner. The expert explained that the emergency brake is integrated inside the rotor, so no special tools are required to reset the caliper.
