1998 GMC Sierra ROTOR REPLACEMENT
DRTOYS
  • 1998 GMC C1500
How do you replace a front rotor on a 1998 GMC Sierra Pickup truck? Do you just pop it off or is it screwed or bolted on?
Thursday, October 11th, 2007 AT 1:56 PM
TROY WIL
Im sure you are talking about your front brack rotor. In order to replace rotor. It is held on buy key nut. You have to take cotter pin out and unscrew nut on spindel. You will have inside bearing and out side that you should go ahead and replace its only around $20.00 for both. You also need to take caliper off. It is held on buy twom allen bolts. Its not as hard as it looks. Troy
Saturday, March 8th, 2008 AT 10:49 AM
