1992 GMC Suburban ABS Sensors Melted
AUSTRALIANFARMER
I have a GMC 1500 suburban, 1992 model, manual shift, approx 100,000klm and the abs sensors on the front wheel have melted. I had new discs and pads added not long ago. Why have they overheated? they were not under any heavy work loan at the time- towing etc
Oct 31, 2007 at 11:31 AM
SERVICE WRITER
  • 9,123 POSTS
I am more inclined to think it isn't a case of overheating the brakes. When the brakes were done, were there any other things done, like sway bar bushings maybe? I have seen guys unintentionally burn other components while try to work on another one.
One tech I know cut a drivshaft in half while cutting an exhaust pipe with a torch. :shock:
Oct 31, 2007 at 11:40 AM
AUSTRALIANFARMER
No other work was done apart from the brakes, the warning light has stayed on since and came on within 2 hours of the brakes being repaired
Oct 31, 2007 at 11:55 AM
SERVICE WRITER
  • 9,123 POSTS
CAll the shop that did the work and explain what you found. The sensors don't melt without unusual help in my experience.
I have seen problems with metal shavings, debris etc getting on the sensor face and causing the lights to go on and abs malfunction.
Oct 31, 2007 at 12:07 PM
Suggested Repair
Contact the shop that did the brake job and have the front ABS sensors inspected. They likely were damaged during the repair rather than by normal braking heat. Also check the sensor faces for metal shavings or debris that can cause the ABS light and malfunction.
Conversation Summary
The owner of a 1992 GMC Suburban said the front ABS sensors melted soon after new discs and pads were installed, and the ABS warning light came on within two hours and stayed on. No other work or heavy towing was done. The expert doubted ordinary brake overheating, suggested the sensors were damaged during the brake repair, and advised calling the shop. Debris or metal shavings on the sensor face can also trigger the ABS light.
