1993 GMC Suburban Shift Indicator
MOKIEPOET
  • 6 POSTS
I took my dash apart last week and put it back together on my 93 suburban(trying to get to blower) and the gear shift indicator is wrong now. I have looked in my book, but I can't find how to adjust it. I would appreciate any advice! Thank you
Jul 19, 2007 at 3:10 PM
CLY
  • 308 POSTS
I think that has small wires that come from the bottom of the cluster and rap around the shifter bowl on the steering column(rightside). There is a clip that slides onto the bowl you can move it up or down to get the neddle were you want it....
Hope this awnsered our question....
Cly
Jul 19, 2007 at 10:16 PM
MOKIEPOET
  • 6 POSTS
I have the wire attached already. Can the little flat piece of metal on the steering column that the wire is attached to just be over?
Jul 20, 2007 at 2:23 PM
CLY
  • 308 POSTS
that is correct...move it around until the indicator is were it should be...
Cly
Jul 20, 2007 at 2:28 PM
MOKIEPOET
  • 6 POSTS
Thanks for the conformation. I didn't want to try it without someones ok- I was afaid of breaking it.
Sarah
Jul 23, 2007 at 2:29 PM
Suggested Repair
With the indicator wire already attached, slide the clip or small flat metal piece on the right side of the steering-column shifter bowl up or down until the gear-shift needle lines up with the selected gear.
Conversation Summary
After reassembling the dash on a 1993 GMC Suburban, the owner found the gear-shift indicator reading incorrectly and could not find an adjustment procedure. The expert said the indicator wire wraps the shifter bowl on the right side of the steering column and that the sliding clip can be moved. The owner confirmed the wire was attached and asked whether the small flat metal piece could be repositioned; the expert said to move it until the indicator is correct.
