I own a 1996 gmc serria c1500 with 4.3l and 153266 miles. Problem check engine comes on for tps code PO122. And engine dies out at idle wont start right away, starts after several tries and idles high. I have replaced tps, egr, ect, oil pressure switch fuel pressure sensor. I checked the ohnms to the blue, gray wires and the ground wire all check. Oh the code does not come all the time, truck will great one or two days. Then code comes time after time after being cleared with a code scanner. Please help. ? [/B]
SPONSORED LINKS
Friday, March 3rd, 2006 AT 10:08 PM
