2000 GMC Sierra No-Start on First Try Fix
Has anyone considered the possibility of it being an ignition switch problem? I would have looked at an injector problem until you mentioned that no matter what the second time it fires.
Check for spark when you crank for the first time.
Wen you start (or attempt to start) do you go from the off position immediately to start or do you go from off to run (for a second or two) then to start?
You might have a bad relay somewhere that is not allowing the computer to initialize properly.
Try looking at the connections entering the fuse holders (large one under the hood and the small one inside). Poor connections could cause a multitude of problems.
When you removed the starter module, did you remove the wires as well or just unplug the module?
In General is sounds like one or more bad connections somewhere.
Good Luck
When I removed the starter module, I didn't remove the wiring. I have no reason to believe that the previous owner lied about when the problem originated, so I believe he is correct that the issue is unrelated to the remote starter.
I have discovered that the problem with the radio seems to be thermal. It hadn't done it, and doesn't do it until the mercury hits about 90 degrees. It is also not entirely caused by using the turn signal. I have since had it shut off while just driving, but it seems to be an electrical issue as well. I notice it happens mostly when I use some additional electrical power, such as the turn signal, or to put the windows up or down. It has shut off while just driving only a few times. When the problem does show up, I have a hard time making it happen again to try to diagnose the problem. It seems to have a mind of it's own, and it only shuts off when it wants, and comes back on a few seconds later.
Again, I have no idea if the radio problem is related to the starting problem. They both seem like electrical issues, but only the radio problem is temperature specific. I have the starting problem all the time.
It appears that the computer is being held in boot-up too long.
I would try to reset the computer and clean the connectors into the unit.
Easiest way, remove the battery connections and wait about 20 minutes (the computers have large capacitors for filtering). Remove the connectors and spray them down with some contact cleaner (Radio Shack). You can use a brush (non metallic) to help clean the contacts.
Other than that, I can only suggest to check the wiring/connectors to the ignition switch and the through the firewall (usually not the case but you never know).
One additional question. When the vehicle idles, is it smooth or rough (thinking throttle position sensor not working properly)?
Good Luck
I will try resetting the computer. I will also try cleaning the connections, but can you tell me where the computer is located? I have a repair manual, but it doesn't mention the location anywhere in it.
When the truck starts, it runs like there is absolutely nothing wrong with it. The idle and acceleration are both very smooth.
Most of the models I have seen, the computer was mounted on the driver side fender above the anti-lock brake pump. Mine (1997) is about 12x6.
You should see a large heat sink (fins) with at least 2 multi-wire connectors plugged into it. It needs the large heat sinks because it is directly firing the injectors which could draw up to 20 amps at high revs.
After you remove the battery connection, pull the fuses labels ECM (electronic control module) probably 2 of them and check for corrosion or possibly bad (weak) fuses. You might even try just changing them. Your repair manual should tell you what fuses are for what.
After you reset the computer you might notice that the tranny will shift different for a while because it will be reset as well.
This is a definitely a strange problem!
Good Luck
Suggested Repair
Inspect the in-tank fuel pump hose for a pinhole worn by contact with a metal float rod, and replace that hose or the pump assembly. Confirm fuel pressure and prime before the first start. Treat the intermittent radio shutoff as a separate electrical issue and check its power feed, grounds, and related connections.
Conversation Summary
A 2000 GMC Sierra 1500 with a 4.8L engine cranked but would not start on the first key cycle, then started immediately on the second try. A fuel pressure regulator and remote-start module were already ruled out. Suggestions included the ignition switch, spark, relays, fuse and connector problems, and an ECM reset. Another owner reported the same symptom fixed by a fuel pump. The owner later found a pinhole in the pump hose where it rubbed a metal rod, spraying fuel inside the tank, and planned to replace the hose. The radio also shut off intermittently under heat or extra electrical load and appeared unrelated.
