Thank you for you input but I have found on other forums that I will have to hook my truck up to a scanner / computer to have the timing fine tuned to the cam shaft sensor.
I have lined up the mark on the balancer wheel with the mark on the timing chain case to get the #1 up on top dead center. I have also tried taking the distributor out and moving it back and forth a tooth or two but it then runs worse. Also tied to adjust the distributor by loosing the distributor clamp and turing it ever so slightly and it still has not worked. I am pretty sure I have it in the correct position now as it does run but not great.
So I guess I need to have it hooked up to a sensor or computer now but thank you for your input.
Sunday, April 12th, 2009 AT 12:18 PM
